-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Power Steering Bracket Snapped (http://forums.pelicanparts.com/showthread.php?t=564327)
Aenyone 09-14-2010 11:47 AM
Hmm. Ok.. it looks bad.
With a replacement bracket, what am I looking at as far as reinstallation?
I mean, I could use the forearm workout turning the wheel without power steering, but I'd like to have it back.
The car is a 1989 944 N/A.
http://img823.imageshack.us/img823/3184/p6130058.jpg
Rasta Monsta 09-14-2010 12:54 PM
You need a new lower balance shaft cover ("gear carrier" in PET). If you have to pay a technician to replace this, it will cost you a fortune.
smokin_944 09-14-2010 01:24 PM
Holy crap!! How did you manage that?
Rasta Monsta 09-14-2010 01:25 PM
Easily in a 924S. . .the ps pump hangs way below the bodywork (BTDT).
968rz 09-14-2010 01:37 PM
It happened to my 968 in the same place, I took it apart and a welder I know was able to fix it and add a bit extra to make it stronger.
Many think it is caused by excess vibration from weak motor mounts on miss aligned balance shafts.
Aenyone 09-15-2010 08:00 AM
Not sure. But I did have to replace the little tension bar a few times. It kept snapping.
85Porsche944 09-15-2010 10:59 AM
I have had one break from loose bolts on the A/C compressor, and another break from old motor mounts, and yet another from my own over-torqueing. You have to pull everything off the front of the engine to get to it.
GARG 09-15-2010 03:54 PM
that happened to mine too, from the adjuster bolt vidrating loose.
I just used the rear mount and its been fine since.
tks gary
