944 Turbo shuddering brake pedal
After changing the 2 calipers and discs, the brake pedal when pressed still shudders. Any ideas what I should try next???
Old 09-15-2010, 12:36 PM
yarfk
kfray's Avatar
If you did the front brakes, then check the back brakes
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 09-15-2010, 01:56 PM
racer's Avatar
What do you mean by "shudders"? Did you change the fronts or the rears? Did you change the pads as well? Is it the "abs" being triggered (assuming you have ABS?)
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 09-15-2010, 01:58 PM
KEV951's Avatar
if you feel the pedal pulsate any time brakes are depressed fairly hard or soft, its your rotors. Measure them to see if they are out of round, if you have abs, this could also be part of the problem, no abs, find some known good used rotors and swap and drive, or buy brand new ones
Old 09-16-2010, 09:21 AM
