Taking out a S2 instrument cluster
Hey guys
I need some quick tips to take out the cluster. and whether or not the steering wheel needs to come off. Many thanks SmileWavy |
Yep you need to remove the steering wheel - then there are 9 screws holding the gauge cluster cover - and four more for the gauge cluster it self, +++.
See Clark's Garage Shop Manual for an excellent write up procedure - Clark's Garage Home Page Shop Manual - Gauges - Electric 07 |
Excellent link !!
Many thanks, speedo gear replacement time!
IIRC, You have an Air Bag. Disconnect the Battery for at least 30 min. to disable it and be very careful after that. That bag carries one heck of a wallop to the face.
Ref: Clark's garage.com If this is an air bag equipped car, you'll have to perform the air bag reset procedure to reset the air bag warning light. On newer 944s (S2) and on the 968 this must be done at the dealer with a Bosch-Hammer diagnostics tool. Cheers, Larry |
He pulled the cluster and changed the stock instrument lights to LED. |
| All times are GMT -8. The time now is 01:03 AM. |
