924/944: Installing a fuel cell
Other than building a frame work and installing a 8 gallon cell in the right rear area......has anyone come up with any other method??
Where the rear seats go (you need to build a bulkhead with either method) but it should help reduce the pendulum effect as the weight changes due to fuel usage.
Or replace the stock tank location with a custom made cell. Or mount it in the trunk area (CoG is a bit high though) |
| All times are GMT -8. The time now is 10:31 AM. |
