Early 1984 944 sunroof motor
Hi. The sunroof on my 1984 944 is not working. I can see two wires going in to the motor. Which is live and which is neutral? Could I test it in situ? If I need to remove it, do I have to remove the whole assembly or can it be easily done? Thanks. Leonard
They are both "live" depending on which direction you want the motor to turn (hint: see window regulator motor).
Good luck, George Beuselinck |
