James Chimney
968 sway bars on my 85.5 944???
Ok got the 968, 30mm front, 19mm rear sway bars in the car today (old 24/14mm) and took it for a quick drive...it feels great (also adjusted the rear Koni's 1/8 turn off of firmest setting, was 1/8 off softest, front 1/8 off firmest)
a few questions. 1) the rear has 3 holes on both ends (I used the middle one) what are the 3 holes for (different settings, tension?) 2 the front was a bear, the bushings that attach from the drop down point and have a full circle clamp squeezed out the bushing and is not 100% "clamped down" (they are tight), the top bolt is touching but the bottom bolt can not squeeze down enough to make it flush (I think the clamp is to small) What do I need to fix this clamp on the bushing? and what hole should I be in....yes I know but lets keep it clean. thanks |
That Guy
1) The holes change the stiffness of the bar. If you think of it in terms of overall length; the hole that makes the bar the shortest is stiffest, and the longest overall length is the least stiff.
2) The front clamps are a different size for the larger bars. Find used clamps from any car that had a 26.8mm or 30mm front bar, or just buy the larger one needed.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
James Chimney
also the rear drop down links (I could not get the old rubber out to install the new ones...didn't want to F it up) do these really have to be changed?
James, you got a nice M030 setup, get 2 new retaining brackets $25.00 and new rear drop links $69.99. Cheap IMO. There is no point in getting good stuff and falling short on the details.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
James Chimney
Garage Helper
Pelican - and they are a little less here...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
