-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Transmission Fluid Change (http://forums.pelicanparts.com/showthread.php?t=567024)
CKniht90 09-29-2010 02:56 PM
Alright finally getting around to chaning the trans fluid. I got some Castrol Manual Gear fluid. This is a good brand? This is the fluid that came up on the computer when I asked the guys at Advanced Auto Parts what kind I needed. Also a friend said I might need additives for it too? Do I need anything to add to the trans fluid? Or just strait Trans fluid?
KEV951 09-29-2010 03:40 PM
does your car have a factory lsd?? (limited slip differential) meaning power is distributed to both rear wheels and not just one side. if so use swepco or redline, if not your fine with what you have.
CKniht90 09-29-2010 03:52 PM
Well I'm not sure. I have a 944 1988 4cyl 2.5L 5speed N/A Celebration Edition. How do i find out what it is?
ernie9944 09-29-2010 03:57 PM
[QUOTE=CKniht90;5588055]Alright finally getting around to chaning the trans fluid.
Don't forget to remove the top plug first & use the rigth wrench ,if you could get one of these it will make life less miserable for you.;) http://forums.pelicanparts.com/uploa...1285800977.jpg
KEV951 09-29-2010 04:19 PM
jack the car up from the back just enough to get the rear wheels off the ground, turn one wheel in one direction, if the oposite wheel spins in sink with the spinning wheel ( same direction forward or backward) you havd lsd. if the other wheels turns the other way than the way your turning, you have a non lsd or open differential.
pigeon 09-29-2010 06:25 PM
Call Porsche America and ask them for the option list. They will want you to fax proof of ownership (I sent my registration) and will call you back with a list of the options on your car. That's how I found out my 951 has an LSD among other things.
I used Redline recently and it helped with a slight grind into 3rd. I'll probably grab some Swepco and change it again soon - the local PCA chapter has a discount with a supplier. I'll probably also get some BradPenn oil for the next change too.
oliver88 09-29-2010 06:35 PM
Redline MT 90. GL-4 rated lubes are specified for 944 trans.
Grandad#3 09-29-2010 06:41 PM
X100 on using Swepco 201 75W90 Trans Gear lube and Brad Penn 20W50 engine oil.
Check out the link below and it will tell the location of the sticker for all your codes and what your Option Codes mean.
944online.com - Porsche 944 Option Codes.
http://www.944online.com/cgi-bin/forum/forum.cgi?board=944Talk;action=display;num=1273219 879;start=0#5
Cheers,
Larry
pigeon 09-29-2010 06:52 PM
Oops, forgot about the option code sticker, probably because some DPO painted over or removed it on my car...
James Chimney 09-30-2010 01:40 AM
hope it is ok to post this here, here is Clarks garage's trani fluid change Manual Transaxle Fluid Change I used a very small oil can with a pump (took for ever and it takes 3 bottles) Yes remove the top bolt first (do not drain it until you know you can refill it some say hit the bolt to "wake it up" I hit every thing on this car with WD-40 before starting to loosen up the "old stuck nuts and bolts) I believe it is a 17mm hex key head
John_AZ 09-30-2010 05:37 AM
Yes to the 2 synthetic oils mentioned above.
I use Valvoline HD gear oil. It is for our hypoid gears and will not ruin/eat the yellow metal syncros. Cheap.
http://forums.pelicanparts.com/uploa...1285850175.jpg
John
VINMAN 09-30-2010 05:40 AM
+1 to the Valvoline. The Castrol will work just fine also.
CKniht90 09-30-2010 12:48 PM
Alright guys. Greatly appreciated. Pelican parts forums never fails me :)
mayPOR944 10-09-2010 11:05 AM
i tried swepco and others im sticking to valvoline good affordable stuff
matty89 10-11-2010 11:51 AM
whats the difference between the gl-3 and 4 its good for yellow synchros and the other not ?
RedBaron 10-11-2010 02:18 PM
Gl4 is what Porsche recommends. I used Redline MT90 and it's perfect for my S2 LSD Transaxle. I don't know the difference between gl3/gl4, but I know the difference from Gl4 to GL5 is that GL5 contains a high sulfur content.
choinga 10-11-2010 04:09 PM
my tranny is a little whiney at low RPM's when engaged because my PO put in a fidanza flywheel when he did the clutch...so I put in Swepco 210 (yes, 210 not 201) and love it. It's not silent, but it really quieted it down nicely (and I had tried Royal Purple, Lucas and 201 previously).
I'm sticking with 210 - a little harder to find, but worth it IMHO. I have a LSD.
Slam 10-12-2010 05:41 PM
Lucas: Lord of Darkness, and I don't just mean Britcar electrics...
