"THERE IS NO SUBSTITUTE"
im wondering why my brakes seem to shake when slowing down from fast speeds, u might say from warped rotors doestnt seem like it because today i did triple digits and slowed down no shaking this time + they seem to squeal from on side and when front tires in air they keep spining for alongggg time
might do new brakes new year zimmerman cross drilled brakes and pagid pads |
have you made sure all of your hardware is present and properly fastened? have you checked for end play?
when i grab the wheel hard could kind of hear a clunking next day went away i have no clue and no brake hard were has not been checked looked like plenty of pad hasnt been checked or changed for at least 12 years could be originals who knows
did do a dry park test tie rods due seem fin not many miles on car, and could a clunking on from passanger side have something to do with the brakes
it might be suspension bushings. maybe control arm bushings? probably not but it might be worth checking out
so bushings would make it shake stoping from high speeds, and some times my brake pad light goes on shut of car turn back on is off i might have to look into more detail either way next season will deff take brakes off if they want to since they been on there for a very long time
In the Fires of Hell.....
A clunking noise can also be that your bolts holding your steering knuckle to the strut are loosening up. This is a very common issue with 944's, especially if they are tracked.
For me, it was a clunk when going to full/near full lock at slow speeds. The camber was out and I had to have it aligned again. Now I check those bolts before every track day. Many racers weld some supports to the struts, or tack weld the bolt to the strut to prevent movement. Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
I would look into the bolts as keith said. the reason I suggested bushings is because they have lead to weird issues for me before. over time they not only wear but flow and it will lead you to strange problems.
Back from Beyond
Have you adjusted your front wheel bearings lately? Cheap and cheerful!
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
how do you adjust the front wheel bearings?
