PRMN944
1983 944 Auxiliary air valve
The hose from the water/oil separator that connects to the auxiliary air valve is squeeze flat out when the engine is fully warm, but not when it is cold.
This happened after I replaced new hose. I could not tell from the old hose due to hard as plastic tube.
Does anyone has the same issue on their early 944 model?
Old 06-30-2008, 01:30 PM
AKCJ's Avatar
This is one of those things that makes you say " hmmmm".
Red 83 944
Old 06-30-2008, 03:45 PM
that hose doesnt go to the aux air valve on my 87 924s it goes to the rubber piece that connect the throttle body to air box i think this is called the j boot a small hose should be at the back of the intake to connect to the aux air valve will try to find a pic
Old 10-12-2010, 01:17 AM
I would have to check on mine when it's running. as i recently replaced that hose as well with a newer flexible hose from the hard like a rock original.
They trany is off so i'm not sure if it would be a good idea to turn it on and find out just yet :P
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 10-14-2010, 01:03 PM
