-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Looking For; Engine Rebuild Resources (http://forums.pelicanparts.com/showthread.php?t=571134)
jamesjedi 10-22-2010 07:33 AM
I am looking for a "Clarks Garage" type of on-line engine rebuild resource for an 86 NA. Also looking for information on how to read leak-down tests.
I came back from the track with high oil pressure, and a rough running car.
I will have to do a Little more investigation, especially a leak-down test.
Help, as always, is appreciated.
James
krystar 10-22-2010 08:04 AM
how high oil pressure? sure yer gauge is working? stuck oprv would be first guess
jamesjedi 10-22-2010 08:15 AM
The dip stick popped out and sprayed abut 2 litres of oil in the engine compartment. Gauge is also high, and engine sounds rough. I do have to do more investigation.
jamesjedi 10-22-2010 08:41 AM
I have looked up the OPS unit on Clarks. Would the engine run rough? Is oil pressure high, or is the gauge showing a high pressure while the engine is at a normal pressure? My dip stick has been pushed out of the tube.
jamesjedi 10-22-2010 11:51 AM
I am going to close this thread and start a new one on OPRV and OPS.
John_AZ 10-22-2010 12:34 PM
Help, as always, is appreciated. James
Leak down info:
Compression-leakdown test
OR
How to Perform a cylinder leak test efficiently « Bentley Publishers
OR
Leak-down tester - Wikipedia, the free encyclopedia
GL
John
jamesjedi 10-22-2010 01:48 PM
Thanks again John.
