944 sidemarker light stumper
On my 1984 944 I cant figure out how to get the bad bulb out of the side marker assembly. I have the assembly out but I dont see any way to get this bulb out. What is the trick?
Remove the weather cover, then remove the socket assembly by bending slightly the tab that holds it into the light, then remove the bulb from the socket assembly.
Good luck, George Beuselinck |
dkbautosports.com
front side lamps . there is a a rubber boot over the socket assembly pull the boot off from were it sits . under the boot you will see a white flat plastic tab (it faces to the front of the car) with a little screw driver push the tab towards the front of the car . the metal lamp socket will then fall out or with just a little pull will pop out as your pushing the tab . then hold the metal socket in your hand and turn the light bulb to the left and pull it out of the socket . rear side lamp . remove the black plastic cover that is on the inside of the QTR panel . there are two white thumb nuts to do so . from there is the same as the front lamps for bulb replacement . the flat white plastic tab still faces to the front of the car . there is no need to remove the hole lamp assembly to change out the bulbs .
