85.5 Rear of Engine - 3 Ground Locations?
There are three ground wires wanting to connect at the rear of the engine.
Large ground from the battery is obvious and I labeled this properly, so its connected.
There are two more brown grounds coming out of the DME bundle - one with a large connector and one with a smaller connector. The first looks like it wants to connect at the same bolt as does the large battery ground - would this be ok? I could also connect this to the back bolt of the rear water-neck. The second brown ground wire (with smaller hole connector), I've labeled, but cannot find its mating label and have no idea where this goes. Somewhere near the other two...but I cannot find any bolts of the right size for this within reach of this ground.
I've done lots of searching for ground locations for the 85.5, but cannot find anything specific enough with good photos. Any hints? Thanks!
Old 11-11-2010, 12:02 PM
Have a look at this string from Techno Duck. Should be exactly what you are after;
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/422736-late-interior-groud-point-locations.html
Old 11-11-2010, 07:35 PM
if i am not mistaken it connects to fire-wall.
Old 11-12-2010, 09:20 PM
now how about a vote on pan gasket
ernie9944's Avatar
Don't know about the 85.5 but on the early car (this is some of the grounds connections at the rear of the motor & to the firewall.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-12-2010, 10:10 PM
smokin_944's Avatar
Holy smokes Ernie! I sure can't see mine that easily... And there's an open hole to contend with at the back. Drop a nut in there and you are fubar'd.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 11-13-2010, 06:52 AM
ernie9944's Avatar
Yes you got to very carefull when working in that area & make sure you cover that hole in the bell housing ,like your saying God forbid if you drop anything in there.
Old 11-13-2010, 07:10 AM
There is another smaller threaded bolt hole in the block or intake in the vicinity of the large ground for the smaller ground. My bolt is snapped off and I have been unable to get an easy out in to repair it. So I bolted the ground to the bracket for the flywheel sensors.
Old 11-14-2010, 04:44 PM
