rubber molding piece - what/where is it?
there's a rubber molding piece that goes on the transmission carrier, on the back and bottom of the door edge opening, around the hole in the body in the engine compartment where the fuel/brake lines and wear sensor cable pass through. it might be in other places. it has a hatched pattern on the surface - it is not smooth. it is not a fat rubber weatherstripping piece.
if you know what I am talking about, what is this piece called and where is it in the PET? It is not easy to find for me. I have not found it in the Pelican catalog either on multiple occasions.
87 944 NA
Last edited by Bukowski; 09-04-2013 at 01:07 PM.. Reason: Added "back and bottom of ", change "door edge. To "door opening"
Old 09-03-2013, 08:43 AM
Frankly my dear....
rhett's Avatar
Yep, know the stuff. It probably isn't in the PET as when the car was being built the assemblers would have just cut this edging trim off of a roll, as they required it. Yes, it does appear in different places, a couple in the engine compartment where the brake pipes and fuel lines go into the strut tower and two pieces on the torsion bar to stop the handbrake cable rubbing on an edge.
Any good automotive trim supplier should have something similar, otherwise go down to the local wrecking yard and pull a load off of a parts car - any kind will do.
Google automotive edging strip...lots of pic's.
The metal inside it does rust and so it can become useless and fall off, so getting some new stuff is a wise idea. It seems to be a PVC rubber composite. Hope that helps.....
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 09-03-2013, 11:29 AM
tamathumper's Avatar
Is it the same checkered hard rubber that covers the "lip" at the bottom and back of the door opening?
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 09-04-2013, 12:54 PM
I think so - that's what I meant when I wrote "door edge".
87 944 NA
Old 09-04-2013, 01:05 PM
here's a pic
87 944 NA
Old 11-12-2013, 03:38 PM
