need advice-air intake
Got my intake plenum off and looked inside---its caked with blackish crud. Question is??? 1) do I forget about it?, or, 2) clean it? If #2, what's the best way--process and products. Any advice is appreciated.
Curtis' '87 944 n/a
Old 01-27-2002, 06:56 PM
Obin Robinson's Avatar
could just be some carbon deposits and dust, ignore it unless it's really really bad.
clean it how? get some "throttle body cleaner spray" for about $2 a can at an auto parts store. hose the inside with it... and i mean really hose it down with the stuff. then use some rags to thoroughly clean it. if you need something to scrub it with, use a regular cheapo kitchen sponge that comes in a pack of three for a dollar (no sense going out of your way because you'll want to chuck it out after scrubbing it against a dirty car part soaked in chemicals..
also, after using the throttle body cleaner spray, i often go over things once again with some nice degreaser. the one i use is called "Purple power" and it works really well.
good luck!
obin
"Resale value": the phrase most often uttered by people who are afraid to admit they can't afford their car.
Old 01-27-2002, 07:14 PM
