If you are going to jump in and do your own then you cut off the old boot with a sharp knife (Easiest way is an Exact-o razor). Other wise Pelican sells the Knob and Boot already assembled (see in this thread above) so you can just toss the old into a save box.
http://forums.pelicanparts.com/uploa...1315484444.jpg http://forums.pelicanparts.com/uploa...1315484478.jpg http://forums.pelicanparts.com/uploa...1315484561.jpg http://forums.pelicanparts.com/uploa...1315484618.jpg http://forums.pelicanparts.com/uploa...1315484652.jpg:D Pelican do not supply the shift lever with boot/knob ,nobody does you got to buy it separately.same for the white plastic bearing shell (bushing). |
matthewb - sorry for the slow response - the boots i replaced were for my son's and my car - we are on a strict budget here so we went to the fabric store and bought a piece of black leather and hand sewed them ourselves - took about 2 hours each - total cost for both was $30 - my son's car is pretty much a total redo so i want him to get as much hands on experience as possible - they came out great
That is awesome! Every bit.http://forums.pelicanparts.com/support/smileys/clap.gif
http://forums.pelicanparts.com/uploa...1315656477.jpg(bushing)http://forums.pelicanparts.com/suppo...s/beerchug.gif |
Ernie,
Then I need to replace all three. Shifter lever pin is worn, both boots shot and the bushing may be shot, too. I'll plan to buy the shifter lever, combination boot/knob and bushing all separately to replace what I have now? Where do I get the C clip that holds the knob to the lever or is it not needed? Thanks for the reply! |
Another option is to drill out the pin and replace it with a bolt and nut. I tend to do things the hard way, but it's light on the wallet.
As for the clip attaching the shift knob/boot assembly to the lever? Drill that out too? The old one doesn't have a clip and pelican doesn't sell it...
Drill out the hour glass shaped shifter pin, then replace with a nut and bolt.. The plastic socket is still original on my car. Not sure who mentioned it was a problem, but they're full of shyte.
Ernie, thanks, you gave me all the info and parts numbers I need to do the job. The rattling loose shifter and tattered boots will soon be history. Again thanks. Apologize for hijacking someone elses thread. It sounds like the originators of this discussion did a fine job restoring their 944. The fun of these cars is there all just a little different and a new challenge. All the best to everyone!
If you lost the e-clip that fits on the end of the shifter shaft, I read recently that you can use a 5/16 e-clip. Easily found at the LAPS or hardware store. YMMV
| All times are GMT -8. The time now is 07:34 AM. |
