-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Hatch struts (http://forums.pelicanparts.com/showthread.php?t=583753)
hpaulb 01-05-2011 08:48 AM
Hatch struts
I keep reading threads saying not to put new hatch struts on because it will damage the glass seal. What's up with that. My hatch keeps falling on my head. Looks stupid with a stick under it.
Anyone replace these?
Jrboulder 01-05-2011 12:07 PM
Look at the hatch and think about how it would get pulled if you applied force to the rear of the hatch. New shocks ruined my hatch and I'm not taking any chances with the replacement
racer 01-05-2011 01:38 PM
I risked it. Put on some new ones late last summer. Do note that left and right are DIFFERENT should you proceed with replacing. It is a bit of a shock to see the hatch launch right up when triggered, just like when new. It WILL require two hands and some force to close compared to your old worn out struts.
porsche4life 01-05-2011 02:16 PM
My factory struts are still plenty strong, they have caused my hatch to leak for the second time. I no longer hook them up, I got my hands on hatch that is still factory and doesn't leak. I plan to beef the urethane up a bit and then put that hatch on my car. I may use the one off my car as a donor frame for the race car....
djnolan 01-06-2011 05:32 AM
The hatch seal probably fails for two reasons, the struts pushing it backwards and just plain old gravity with a big piece of glass sliding downhill and being jostled constantly. The hatch frame develops a slight bend near the 45 degree angle because of these forces. The hatch frame gets slightly longer and the glass separates from it at the top. New struts will certainly accelerate this. (this is just a theory)
wild man 01-06-2011 05:54 AM
So did I. It was like a year ago, with no problems (yet, anyways). But I do have replacement hatch, if I do run into any problems. I think having to prop it up using a stick or whatever, puts the same (or even more) stress on the frame.
race2fast 01-06-2011 07:13 AM
I have only had 3 944s and I have replaced the rear hatch struts on each car. You are right, looks stupid with the hatch sagging or you design a custom "hatch support". I went to my local AutoZone Part #B95514 (Mighty Lift)and have them order a set from their warehouse. cost $47.98. each. Installed in 1/2 an hour. I needed to play with rear window defroster connections (but who needs that anyway?). The first time done I got a pleasant suprise..... With the new struts and the new found lift, my electric latch actually worked. NOW THAT IS COOL when you can reach in , hit the switch, and the rear hatch opens. (beats the beans out of the "designer support")
So go ahead, make your day and change them. It is worth it. (helps sell the car every time)
Jim.
Also check out the #D251 Duralast Brake Pads for $15.99 and a "lifetime " warranty. You can't lose.
porsche4life 01-06-2011 07:20 AM
Dude, cheap brake pads are just that... Cheap....
race2fast 01-06-2011 07:25 AM
but they still work.
hpaulb 01-06-2011 11:21 AM
Thanks for the feedback. I think I'm going ahead with replacements. I use my defrost in fall and spring and one side electrical connector is no good anyway. Glass can be resealed. I really like the idea of using the auto hatch release and it opens on it's own. I never saw this as mine were never strong enough.
Slam 01-06-2011 12:01 PM
My $.02CDN (which is almost on par in the US!):
Once you start resealing your hatch you'll be doing it once every 2nd summer. It'll take a leisurely afternoon but it can a stressful job the first time. And once the delamination takes hold you'll be chasing it forever. I wouldn't bother with strong new hatch shocks as they'll just make the damage happen that much faster. Yeah, it's trick to have a hatch raise itself, but after the first time you fight with resealing it the novelty will wear off.
Lifetime brake pads? Beware - maybe they're lifetime because they wear much more slowly than the rotors, and you'll be trashing them instead. Pads are easier to change (at least on the early cars).
89-944NA 01-06-2011 12:20 PM
Jim.
Why not replace them with OEM for $26.00 (left) and $28.95 (right)....To the original poster, I am on my 3rd 944, and in 20+ years of owning them, I have NEVER had a de-lamination problem, and yes, I have changed the struts on ALL of them.
As for the $15.99 Duralast brake pads, I put them on a 1999 Dodge Stratus, and they were worn out within a year....and that was literally on my 84 year old mothers car. Cheap is CHEAP, NOT good or better.
race2fast 01-06-2011 12:42 PM
OOPs. you guys are right. My mistake I purchased 2 set at $47 per set. ($23.99 each lift). I hope you understand my direction to put new and it is worth it.
As for pads and rotors. There are all kinds of combinations out there. You can come up with a great value.
Sorry for your mom. Maybe you let her have one of your 944.... she might like it.
Enjoy the ride
John_AZ 01-06-2011 03:38 PM
I am with Slam on new hatch shocks. I would not chance a brand new set. If you have sunscreen on your hatch like mine, you will ruin the sunscreen when you attempt any reseal around the edges.
Low price brake pads may work but I prefer pads that do not "shed" brake pad dust on my phonedials.
John
massive 08-26-2015 03:29 PM
Changed my hatch struts, wow what a difference,
