help with injector pulse
I have an 83 944 and my fuel injectors are not firing, I am getting spark, in fact I can get the engine to run on starting fluid. I pulled the injectors out and tested them directly off the battery, and they fired and sprayed just fine, so I am sure its not an injector issue. next I tested the electrical wires going to the injectors, each injector was the same story, were both wires going to the injector were putting off a constant 12v. is this how it should be? if not then how should it work.
I also have a new DME relay in it. |
The 4 fuel injectors have 12 VDC supplied to one pin and the DME Computer output pin 15 and 14 pulse to ground on the second fuel injector pin.
I would check the speed and reference sensors. http://www.clarks-garage.com/pdf-manual/ign-02.pdf If Sensors check OK the check the DME computer: http://www.clarks-garage.com/pdf-manual/dme-01.pdf http://www.clarks-garage.com/pdf-manual/dme-02.pdf Once the DME computer is open check for bad solder joints |
so the hot wire pulses to ground to create a circuit to fire the injector?
Yes
so both wires are suppose to be 12v, and the computer pulses one of them to ground?
sounds good, thanks for the help
| All times are GMT -8. The time now is 05:23 PM. |
