Send a message via AIM to hpaulb
Dr side kik pannel removal?
How do i take off this panel? It has the hatch button and hood release on it. I see no screws? I am trying to remove the nut/stud inside the lower A piller for the "door stay base" . Got one bolt out but the other is spinning inside.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 01-12-2011, 06:16 AM
Panel is glued.
Good luck, George Beuselinck
Old 01-12-2011, 06:36 AM
So how do i get to that nut? Do i pry off the pannel? Is the hatch switch and trunk cable handle glued to the pannel????
98 BMW 740i
Old 01-12-2011, 08:13 AM
dkbautosports.com
962porsche's Avatar
there is no access to the hardware for the doors from the inside of the car . the A-piller is boxed in . if its the (door check) that your referring to ? and that what your trying to remove you may have to remove the head of the bolt another way . you may want to try a rotary burr or a small cut off wheel to remove the bolt head .
Old 01-12-2011, 08:18 AM
That it. Except how do i replace it? I need to change the brocken base. I can't leave it with one bolt if the bolt/nutsert spins or falls in..
98 BMW 740i
Old 01-12-2011, 09:45 AM
aj951's Avatar
I had this same problem some time back. Search this forum on "944 door stay base replacement" and it should tell you what you need to know. I wouldn't bother trying to remove the panels becasue there is virtually no access to the top nut on the stay, I tried it. Cutting the head off of the cheeshead and installing a rivet nut worked very well for me.
A.J.
89 944 Turbo
Guru Chip
Lindsey Boost Enhancer
3bar Reg.
Old 01-12-2011, 10:24 AM
dkbautosports.com
962porsche's Avatar
you will have to replace the nut sert once you cut the head of the bolt off . you can either cut an access hole and weld a new nut on the back side or do a nut sert . is the captured nut in the A-piller spinning or is it that just the bolt is spinning in the captured nut ?if its just spinning in the nut sert ? after the head is off the bolt at times you can cut a slot for a flat blade screw driver in the top of the stud that is left and screw it rest of the old bolt into the A-piller and just let it fall to the bottom of the A-piller . then recut with a thread chaser . you may also be able to push a flat blade screw driver under the door check putting outward pressure on the old door check . this may be just enough pressure to hold the spinning captured nut in place for you to gat the bolt out ?
Old 01-12-2011, 10:41 AM
Seems the nutsert is spinning with only a little resistance. I may have to cut the head off and punch in the nutsert or drill it. Just hope the hole isn't to big after that.
98 BMW 740i
Old 02-10-2011, 12:57 PM
