8 valve powder coated cam tower for sale
Freshly coated glossy red cam box/tower for sale! Includes screw caps, end cap, cam gear cover and distributor mount. The "Porsche" letters are machined and then clear coated so they'll never oxidize.
Price is $260 + $40 core charge (pay $300, send me old parts, get $40 refund).
For a little extra I can assemble it with a camshaft, gear, new gaskets and seals. That way it'll be ready to just bolt on.
Old 01-11-2011, 01:07 PM
Is it really that easy to just bolt on and go?
Old 01-11-2011, 04:26 PM
I can put the camshaft in for you and get it all ready for you to bolt on - you'll still have to do:
  • Put engine at TDC
  • Remove distributor cap and rotor
  • Remove timing belt covers
  • Loosen timing belt tensioner
  • Slide belt off of cam gear
  • Remove fuel rail and injectors from manifold
  • Remove cam tower
  • Put lifters into new cam tower
  • Bolt new cam tower on
  • Put fuel rail back
  • Put timing belt on cam gear
  • Tension belt
  • Put covers back on
  • Put distributor back on
Old 01-11-2011, 06:55 PM
Just thinking out loud
mattdavis11's Avatar
The big problem with the deal is, I want my lifters to slide right back in to my cam housing. Granted it is minor work, but it takes time to incorporate lifters if you're changing the cam and housing. If you're throwing in new lifters with the deal...
91 FJ80
84 Ram Charger (now gone)
Old 01-11-2011, 07:34 PM
Half of your lifters will fall out when you pull the cam housing off anyway...
As a special deal, I'll include 8 new lifters for only $600 extra.
Pelican Parts - Product Information: 928-105-311-06-M40
Old 01-11-2011, 07:51 PM
Its a damn good thing I'm flat broke right now. I really don't have time to change a cam tower....
Old 01-11-2011, 08:25 PM
P944GUY's Avatar
Looks Great..What kind of paint did you use..brand
Old 01-12-2011, 07:22 AM
rickharrison's Avatar
...free bump for Van...a good guy.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 01-12-2011, 07:54 AM
Gloss red and gloss clear from Columbia Coatings: ColumbiaCoatings.com - Best Powders - Best Service - Best Price!
Old 01-12-2011, 11:41 AM
AKCJ's Avatar
What he said. . . .
Red 83 944
Old 01-14-2011, 02:28 PM
KEV951's Avatar
can you do other colors like light blue? my cam box is already stripped and sanblasted , ready to coat. The end cap ,dist mount and cam gear still need to be blasted l, and I would like those to be aluminum or machined finish color. any price break for some slightly less work? can you have the screw caps machined /milled to match the porsche script and clear those as well?
Thanks! and looks very proffesional, and I am sure it will hold up to heat ok .
Old 01-15-2011, 05:15 PM
KEV951's Avatar
pm sent
Old 01-16-2011, 03:04 PM
pjs77's Avatar
PM Sent
Paul - Norwell, MA
1985.5 944 Guards Red N/A
Koni Sports, S2 sway bars
Old 01-17-2011, 04:01 PM
944 Cam Tower
Can you rebuild my Cam tower. 85 944
I removed it to look for noise in valve train and found nothing wrong with the head. Upon close inspection of the tower the oil that drained out contained a lot of metal flake. I fear a bad cam bearing even though it turns very smooth by hand.
Only 25K miles nut PO said he over revved the engine and is making very loud mettalic sound when RPM is increased above 1,000. Looking for any suggestions.
Old 01-18-2011, 04:29 PM
My guess would be the sound is rod knock due to a worn (or failed) rod bearing - and the metal flakes you're seeing up in the head have been pumped there by the oil pump. This engine probably needs a complete and thorough rebuild.
Old 01-18-2011, 06:40 PM
KEV951's Avatar
bump for Van, you guys should seriously hop on board, forget about paint, it won't hold up to anything,
Powder is the way to go for best durability and finish, and Van SERIOUSLY knows what he is doing, I'll post pics of my stuff when finished!
Old 02-15-2011, 10:50 AM
ernie9944's Avatar
Free bump for Van,trustworthy & does a beautiful job on them cams towers.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 02-15-2011, 03:03 PM
