M. Murphy's Avatar
Air Conditioner Removal
Since purchasing an 83 NA last August I have been plagued with Accessory Belt noise problems or more accurately A/C Compressor mounting problems. Since I have no inclination to use the A/C on this car I am considering removing the compressor and as much related plumbing and hardware as possible. The dealer quotes about $66.00 for a new adjustment jackscrew. The parts guy does not think a different Alternator bracket is required. Any advise would be greatly appreciated.
Mike
83 NA Guards Red
Old 02-14-2011, 03:31 PM
That Guy
Techno Duck's Avatar
Yes, you need an a/c delete bracket aswell as a shorter alt. belt. There is a factory delete bracket (944-603-134-02) available and many different versions of billet brackets available as well. The adjustment rod is the same.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-14-2011, 03:42 PM
M. Murphy's Avatar
Thanks, boy was that fast. I will check on the factory delete bracket tomorrow.
Mike
Old 02-14-2011, 03:50 PM
944online.com - Climate Control Find Parts For Your Porsche 944 And Get Your Car Back On The Road.
there's a factory one, it comes with the belt.
i went for a cheaper one on ebay.
and a lot of guys go with the lindsey racing one.
all depends on what you want it to look like really.
Old 02-14-2011, 04:49 PM
Pete R's Avatar
I did an ac delete on my Turbo.. much more of a PIA than I expected. It may be easier on a NA however. (this may only apply to the turbo, but you may want to look at yours first) I originally bought a very cool and trick billet one. I returned it and got a factory one because I noticed that the recessed allen bolts of the aftermarket one would not allow me to retain the brackets mounted to the top two bolts. One was the hook for engine removal and one was to the intake (held some plumbing). You will also need new bolts that are the right length for the factory one (ac delete bracket is thinner than the combo bracket) and a few extra washers to go under the brackets so the have the same height also.
I also ran into an issue with the alt. in it's new position. I had to cut the plastic shroud so it wouldn't hit the steering rack. Also the bolt hit the radiator and would not go in front to back. I had to pop out the encased nut and mount put it in back to front. The empty space of the encased nut fit the bolt head so it worked nice.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 02-14-2011, 07:04 PM
