Abs antilock
I've got a 1987 944 NA with a constant Antilock light on. I performed the proper test on the module to check the speed sensors and they all checked out (that is if I used the meter right).
Next up is testing the relay but don't know how to test it. Any help? ANd also what else could be causing this light to stay constantly on? It's driving me nuts. |
Will program for food
Can you verify the rear half-shafts have the ABS ring? Same for the front.
I know someone (PO) swapped the ABS ring half shafts for non ABS. I had to buy ABS half shafts (used from here of course). Then with sensors hooked up ABS was working. I am sure more knowledgeable folks will also chime in.
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
I didn;t think an 87 NA could come with ABS.. A 944S? yes.. Turbo? yes.. what a rare car imho. Sorry I can't help sovle your issue though.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
