951 Scott's Avatar
Thumbs up Sunroof Gears Replacement with Photos
I recently tackled replacing my worn out sunroof gears..below is a sequence of photos which follow the Clark's garage instructions....total time on this job was about an hour and cost was $14.50 + shipping from Pelican Parts.
Tools Needed:
1.) Phillips Head Screwdriver
2.) Pliers to remove old gears
Tip #1 - when installing the arms, ensure that the sunroof drive gear (viewable thru a hole in the insulated metal tube/cable with sound reducing foam cover, illustrated on the left and right of the motor in the 2nd picture in the initial post in this thread) is in the extreme up position and set both lifting arms on the 2nd to last tooth when in contact with the gears. This will ensure that the lifting arms work in unison and lift the roof evenly prior to putting the motor plates back on.
Tip #2 - see last photo for actual reason why these gears break...it is not crappy engineering....it usually a passenger.
Sunroof removed weather stripping and interior trim removed exposing the sunroof motors
Sunroof motor - just 5 screws to remove the plate, to view drive gear position look for a view hole next to the motor on the passenger side
Motor plate removed exposing the damage gear
Old gear with broken teeth next to new gear
Last photo is of the drain tube..which had separated from the drain, I reattached it and secured it with a zip tie
Suspected Actual Reason these gears break is standing next to my car!!!!!! MY Son....Mr. Button Pusher himself TIM
Old 12-02-2010, 06:13 PM
Born2bwild1191's Avatar
Thank you sir. I'll be needing to do this very soon, and this'll help. Thanks!
'87 Guards Red 924S - First Porsche - SOLD 5/21/10
'67 Red VW Beetle - Restored by me and my dad, 2115cc motor.
'87 951 - Silver/blk, full leather interior - LR Chips - 3 bar FPR - LBE
'92 Ford F150 - Winter truck
'04 Yamaha R6
Old 12-02-2010, 08:22 PM
Desertt5
I did mine a while back. I would advise NOT to ignore Clark's garage procedure to adjust the torque at the motor. Mine worked great till the first time I went to remove the roof. I now have to replace another gear.
Semper Fi
Old 12-02-2010, 08:53 PM
Super Moderator
nize's Avatar
great writeup, adding to the 951 reference list!
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 12-03-2010, 12:28 PM
Adjust the motor torque as per Clarke's Garage, otherwise you will be doing this again. Don't be throwing that poor little kid under the bus. He did not cause the gear failure!!
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 12-05-2010, 06:00 AM
Desertt5
Jon
The kid does look kinda guilty.
Semper Fi
Old 12-05-2010, 07:20 AM
About how much time does this actually take to do ?
72 914 Sold
84 944 Sold
85.5 944 Sold
78 924 (first car) RIP
Old 12-05-2010, 07:34 AM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
that's a very nice car...
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 12-05-2010, 08:42 AM
Toofah King Bad
Rasta Monsta's Avatar
+1, but I'll take that one step further. Loosen the slip clutch completely, and tighten it only as much as is needed to lift the roof. I wouldn't even trust the factory torque settings after the clutch grease has dried for 30 years.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-05-2010, 11:31 AM
IB RearWheelin's Avatar
beautiful 944
Aerodynamics are for people who can't build engines.
-Enzo Ferrari.
Old 12-05-2010, 03:07 PM
Send a message via Skype™ to massive
If anyone needs a tutorial for the earlier 944 sunroof mechanism you can find it here 944 Foot To The Floor: How to repair sunroof on a Porsche 944 (Square Dash model)
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 03-04-2011, 07:24 AM
Tags
sunroof gears
