over heating
Still woking out the bugs on a 968 motor swap on an 87 951. My latest finding is it that the temp spikes when driving in city traffic. I took my 951 out for a drive yesterday and all was good on the highway and country roads alike. The needle stayed around the first hash mark. When I hit some traffic lightsi noticed that the needle went almost to the red. It has never done this before. I turned on the A/C fans and the temp went down, like it's supposed to. When i got home I checked it out and did some easy checks.
The fans come on when the A/C switch is depressed. The fans do not come on when the temp spikes. i got nervous when the needle hit the red and I turned the fans on again with the A/C. Bad thermo switch or bad relay? |
Bleed bleed bleed
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
Already done. There is no air in system. Good thought though.
NY944Turbo
Is the radiator still the original?
my 968 had same symptoms....twice........1st time was because fans weren't switching on and it cured problem.....i replaced thermo/fan switch....2nd time was 2 months later...i took out thermostat and ran it without it and had no overheating...
New rad, new hoses, newer water pump. Old switch and relays. I don't mind replacing but i am curious as to what is the cause of the problem.
...likely the temp switch on the rad...swap it and match it to a new thermostat, and it should work.
Also...how's the tension on your timing belt? Been re-tensioned as required? It may be slipping on the waterpump pulley. Might be worth a look.
Rick Harrison 1988 944S 17 inch Cup 2's, euro bumper conversion Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake MaxHP chipped |
Thanks. I will triy to get it done in the next couple weeks. I still have to retension belts and fix a leaking steering line. The fun never ends!:
87 951 with 94 968 engine, 17" turbo twist, 18" modular |
