Door panel interchange question
Does anyone know if a newer style (post 85.5) door panel will fit in an older (pre 1985) 944 without changing the dashboard?
Or better said, can I use the newer style door panels with the older style dashboard?
Max.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 09-13-2011, 11:36 AM
Not really. The switch plugs and such are diffrent also IIRC. Back when I had an 84 DD and an 86 turbo parts car I looked into it and it wouldn't fit or even look that good.
Jackson
Old 09-13-2011, 12:26 PM
no, and it would look wonky if it did
Old 09-13-2011, 03:30 PM
I'll stick to my old panels then...maybe give them just a little face lift.
Thanks,
Max.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 09-15-2011, 07:19 AM
