944S Compression/Resurfaced head
What is the normal and/ or new compression lbs for a 1987 944S 16valve, and what would happen if you use a regular H/G with a resurfaced head?
Compression Ratio is 10.9:1, and if you are using the Victor Reinz head gasket, all they pack in there sets anymore are the "turbo" gasket...no issues with that gasket.
A quick check of the Porsche PET lists the "turbo" gasket P/N 951.104.374.50 for ALL resurfaced heads (including the M44.40 16 valve head) |
compression test numbers? or actual compression ratio?
compression test numbers depend on alot of things, the two biggest are altitude and the weather. as long as all 4 are within 10psi, that's "good" |
Compression test numbers. My spare 16v head looks like someone cleaned it up some. I can see the machining on the mating surface to the block. Looks flat with a long square. I was looking for the measuring mark and numbers for the head. I saw it some time ago but can not find.
| All times are GMT -8. The time now is 06:27 PM. |
