Blown head gasket
I have an 87 Porsche 944 s with blown head gasket going to repair it my self
but have not been able to locate any literature specific to the 16 valve engine.
Can anyone give send info on where to find it. all information would be
greatly appreciated
Old 04-20-2011, 09:46 PM
i'm sure somone will chime in or i will double check my sources and see. Usualy if you do a search on google for " Porsche 944 download manual" you might find what you need. I know there is a download for the 16 valve engine
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 04-20-2011, 10:34 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
The Porsche Workshop Manual Volume 1-A deals with the details of the 16 Valve Engine - A great Resource for many 944 Owners.
See also: Clark's Garage Home Page The garage/shop manual there has allot of good useful information also.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 04-21-2011, 03:34 AM
ernie9944's Avatar
Edited - illegal to post a link to copyrighted material that was published without permission.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 04-21-2011, 04:28 AM
SLED GUITARIST
Dan Himan's Avatar
I found that i can remove the exhaust manifold, or move them out of the way by removing just the 3 bolts closet to the cab, and not all of them. There is a rad fluid drain plug just above the exhaust at the cab area.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 04-21-2011, 07:35 AM
Are you sure it's a head gasket problem and not just oil cooler seals?
Old 04-21-2011, 08:08 AM
IS THE oil cooler not just on the turbo?
Old 04-21-2011, 09:50 AM
the n/a's also have coolers, just not external like the turbo's. I think the n/a oil cooler seals are much more prone to leaking and causing cross mixing of the fluids than the turbo does.
Click this for more info.
Old 04-21-2011, 10:42 AM
smokin_944's Avatar
robm-951 is correct. Oil cooler seals are one of the most common problems with the N/As. Fortunately it is less work than a headgasket job.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 04-21-2011, 12:57 PM
