-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Engine shakes the cab at idle.. but why? (http://forums.pelicanparts.com/showthread.php?t=602729)
AA_Ezra 04-13-2011 11:53 AM
I have had this engine shake since i purcahsed the car about 5+ years ago and it just won't stop shaking it feal like when i car is goign to stall whiel in the cab.
Woul love some suggestiosn from the grop even those that are uncommon
Here is what I think it might be, pleasee add if i missed one
Motor mounts ?
Ballance shafts out of alignment?
Timing? ( dont see how)
Bad DME?
Distributor cap,rotor,plugs, coil?
Ballance shaft bearings?
Recent service:
Timing/balance belts replaced ( took extra care to align balance shafts)
Replaced a motor mount i should have purcahsed 2 thought only 1 was bad
My motor moutn on passenger side was toast, i thought the drivers was good but i guess not look at the pic. instaled new mount on drivers and put old drivers on pass side.
http://forums.pelicanparts.com/uploa...1302720765.jpg
The good, the bad, the ugly
thanks
krystar 04-13-2011 12:30 PM
betting on balance shafts. real easy to screw up and time em 180deg off
AA_Ezra 04-13-2011 12:41 PM
Would that only cuase low rpm shaking or higher rpm as well?. I will go out and check that right now.
balcsgirl 04-13-2011 01:02 PM
Would a bad ground cause that too???
AA_Ezra 04-13-2011 01:57 PM
ok checked out the ballance shafts the bottom is perfect the top is off by 1/8th of an inch which i think would be ok. Took off the sprocket and it apears to only go on one way so i know i got that right. Are the bottom and top sprockets interchangeable? maybe they were mixed up when the Previous owner had the belts change?
krystar 04-13-2011 02:17 PM
the real question is...are the sprockets keyed on the balance shaft the right way?
the early sprockets had two key slots. O and U. O is upper BS. U is lower BS. way i remember is O=over, U=under. the sprockets were interchangeable but u had to use the right key slot. only way to check as far as i know is to remove the sprocket.
AA_Ezra 04-13-2011 02:35 PM
Ok i will have to check them again. My sprockets only have an ( 0 ) and no ( u ) of any kind.
according to PET upper and lower balance shafts are the same and the sprockets are the same.
Krystar, thanks for all you're input so far. Been dealing with the shaking for too many years and i've reached my limit today.
BUt i did put the key on the (o) position on top balance shaft and the key on the bottom balance is on the ( u) position if it had one. im just glad i scribed a TDC mark on my aluminum flywheel.
Going to check the correct torqe for the shafts and turn on the car the safts are alined a little better now
krystar 04-13-2011 02:39 PM
i remember reading that early (definition of early blurry) sprockets have both O and U stamped. later sprockets only had O stamped, the U slot is still there, just unmarked. ...as you've already discovered. doubt they changed part numbers because U isn't stamped hehe
AA_Ezra 04-13-2011 04:31 PM
Update:
re-aligned the balance shafts toqued and ready to go
Took off the alternator and A/C belt ( just in case it was causing vibration)
Turned the car on seemed to be a little smoother (maybe i wanted it to)
Re-attached the A/C and Alternator belt Turned it on seemed about the same.
Small improvent but the shakign is still there.
Double checked my timing and its on the money Camshaft lines up and the Flywheel TDC is lined up with the outher edge of the Aluminum timing thingy that sticks out
John_AZ 04-13-2011 05:04 PM
My '88 would shake at idle -950rpm-- a couple years ago.
I could not believe it would be the MMs ~60K on odometer.
I had enough and went cheap on the MMs---Hamburg Technic (Deutsche Parts ebay)
I put both on and for a couple of months no vibration.
Then the vibration came back. DO NOT BUY CHEAP MMs
I got another set of MMs-----OEM Porsche $$$ Vibration gone for 2 years +++
Update: Techno Duck just put on a set of Rein MMs. He said they are the same as OEM ----except they grind the part number off. Not cheap but reasonable. Pelican sells Rein.
Picture if you want to measure your old MMs. Measure base to base--no shoulders.
http://forums.pelicanparts.com/uploa...1302739382.jpg
GL
John
AA_Ezra 04-13-2011 05:46 PM
Well looks like my middle motor mount in the picture is wasted just by eyeballing those measurement. You know, I glanced over that page but did not really read it. after readign it I didnt know there was a " pull down test". That middle motor mount didnt really have any ply like the new one. so that one is probly shot.
Don't remeber the brad of them but they were 80$ or so each and lasted me about 5 years so those were a good run.
I alread installed the Uro mount so i don't think i can return it. so i'll just have to ride it out as i have no icome right now. And i still need to order another for the passenger side maybe i might order the more expensive one if i'm able to sell some gear
John_AZ 04-13-2011 06:05 PM
The passenger side always fails first. Exhaust manifold heat.
(This is why you will see single MMs for sale on ebay saying "left side-used".)
Some members will swap the "good--??" left and put on the right for a while. I did this when my cheap Deutsche Parts MMs failed early. I kept the new cheap Deutsche parts MM on the drivers side and put back my original drivers/left side OEM old MM on the Passenger side.
I measured the OEM MM to make sure it was still in spec first.
Helped for a while. Just a thought.
GL
John
AA_Ezra 04-13-2011 06:41 PM
GL
John
that's exactly what i did New URO on the Drivers Old used (???) on passengers side.
Looking at them under the car I do notice that the new mout is pretty much vibration free while the old used one does vibrate.
Makes you wonder how badly the engine acutaly shakes with solid mounts
alfadoc 04-14-2011 06:34 AM
When I got my S2 going (bought it non-running) it had a dreadful vibration. It made the hatch rattle at idle. Double and triple checked the timing and balance shafts, which were correct. Then installed cheap eBay motor mounts that I had purchased before I knew better. That got rid of most of the problem. I still get the occasional buzz out of the door panels at cold idle, but it is a 3 liter four cylinder after all.
These mounts only have 1500 miles on them. When they go bad, which I know they eventually will, I'll replace them with genuine Porsche mounts. I suspect that some of the vibration that I still have will go away then.
p-talk 04-14-2011 08:29 AM
Vacuum leak? Timing and balance belts too tight?
AA_Ezra 04-14-2011 04:06 PM
Timing belts need to be tightened again as they were just recently installed so I'll see if that helps.
Vacuume leak. My exhaust is too loud to hear it. And I don't really now what the best way to check it, propane, brake cleaner, water and soap? I don't want to make the rubber worse
John_AZ 04-14-2011 05:28 PM
Begin by reading Post 7 "Vacuum leaks"
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/458680-idle-drops-low-then-stabilizes.html
I occasionally use "Starting Fluid" for a quick check
GL
John
mayPOR944 04-14-2011 05:58 PM
mine used to shake really bad at idle, even the whole steering wheel would vibrate like crazy, replaced motor mounts best thing i did for that car
AA_Ezra 04-14-2011 08:18 PM
GL
John
Thanks that helped alot i will have to get a different tip for my propane torch as the current one i have automaticaly lights ( BOOM)
didn't know about the 02 sensor that makes sence i would have tried with it still connected
John do you have all these post's bookmarked or is it just from memory that you search for the post
AA_Ezra 04-14-2011 08:19 PM
I'm hoping it will be that simple but i've replaced them both before and it was still the same, Then again i have dotn alot of work to the car to make it run smooth since then.
We will find out once i get the other motor mount and the other test others have suggested
John_AZ 04-14-2011 09:22 PM
Ah,
yes ;)
John
v2rocket_aka944 04-14-2011 09:23 PM
balance shafts dont do a whole lot at idle speed; they are most noticeable at higher rpm. the shaking is definitely the motor mounts. also you can raise your idle speed to smooth it even more.
AA_Ezra 04-14-2011 09:40 PM
Idle is at 800-850 when i start been a while since I've checked it at normal temp As that's almost impossible bc I have a low temp thermostat and fan switch.
Anyways, so what you're saying is that if it was a really bad balance shaft issue like 180degrees off I would notice it at high rpm's as that's when it's at it's worst?
v2rocket_aka944 04-15-2011 09:05 PM
if balance shafts are out of time then you will notice the vibration at most speeds because how the harmonics stack up. but when they are timed correctly you wouldnt notice them really doing much til around 3000ish+ rpm.
set idle to 950 or 1000 or so, it should smooth out noticeably
AA_Ezra 04-15-2011 11:09 PM
Well that makes me feel better, Been a while since i have drivnen it but anything above 1000rpm it runs smooth. Haven driven the car in 6 months but even then 1000-4500 rpm it runs smooth.
I am afraid of a vacume leak wich i wil have to check. Anybody know what the PSI vaccume should be?
John_AZ 04-16-2011 05:20 AM
I have a link ---"yeah, surprise, surprise ;)"
Move down and click on the "scenarios".
How to Use and Interpret a Vacuum Gauge
GL
John
mikepellegrini 04-16-2011 08:27 AM
GL
John
That's a really good site, John.
So good it inspired me to go buy a vacuum gauge. It's a really good, basic diagnostic tool.
AA_Ezra 04-16-2011 09:14 AM
GL
John
LOL, that's awsome john Don't go away any time soon.
according to that test i might be able to tell if the noise i hear in my cam is
A. Weak or broken spring
B. Just the lifter
Sure beats taking the motor apart :P
I'm sure you have done this yourself already, Any tips on were to hook it up?
I was thiking the vaccume at the throttle body as my Brake PVC is old and on there scary tight
John_AZ 04-16-2011 05:07 PM
Mike,
Thanks.
You and your son amaze me with the work you do on the cars.
You and I know there are members who could use his help and pay for his college or Porsche internship (in Germany of course).
Jaime O.
"Plug and Play" :)
John
AA_Ezra 04-17-2011 10:12 AM
What do you think abotu this. I've been searching everywere and a similar idea came up. The car in the video is a turbo so i assume the vacuume hoses will handle more psi?
I was thinking maybe using 5-10 psi?
YouTube - DIY - how to pressurize your 944 turbo intake system
on a side note THE OAS tope tube does not require a hose fitting but i put one on a littel snug on mine is it commong to have a little what seems like oil sray around the top of the OAS?
p-talk 04-20-2011 08:28 AM
Here's a new trick to smooth out the motor - try some Lucas Fuel Treatment next time you fill up. I tried it for the first time last weekend (after seeing this discussion), and it did smooth out the motor quite noticeably.
Don't get me wrong - I'll still be trying the idle adjustment trick, and I do still need to comb through my vacuum system, but the Lucas did really really help.
AA_Ezra 04-20-2011 08:49 AM
Well, Im sure the old gas in the car isen't helping, And it's sad as i just rebuilt/cleaned the injectors. Probly toss some seafoam in the tank instead as i have a bottle sitting right here.
And BTW the home made vacuum pressure tester i made with some soapy watter works great. Found a few vacuum leaks fixed most by tightening clamps but My aux air valve is leaking at the top were the harness conects Seems like a weird place and might be the cause of our Mysterious leaks as it was a very large vac leak
AA_Ezra 04-21-2011 01:54 PM
pulled off my Injector rail and j-boot to seal up some vacuum leak... and
HOLY GUACAMOLE. One of my injectors is leaking and was eating up the nice paint i put on it. And i just rebuilt the damm thing.
Possibly another symptom of why my car was shakign?
