Converting to tilt steering wheel ('83 944), can it be done?
Ok, I do not know about the workings of the steering column or anything, but can my '83 944 have a tilt steering wheel/column adapted to it? Has anyone ever done this? Could I do something like get a boxster rack that had tilt?
I suppose it is theoretically possible.
However, I would imagine it would take quite a bit of "garage engineering" to get it in there correctly. Not to mention being rather expensive. Why do you want a tilt steering wheel anyways? AFJuvat |
If I can do it, I will, for the dad.
Well then, All you will need is a complete steering wheel/column assembly
AFJuvat |
Has there been any progress on 944 tilt steering?
Wow, a 21 year gap update on this thread!
And I haven't seen any tilt steering projects online... |
Just looking 👍
I think I'd go with a quick disconnect steering wheel hub.
That’s kinds what I have been thinking.
newer steering wheeels might have airbags , does yours? modifying this stuff takes it away from the approved crash dummy tests that manufacturers do. Maybe a quick release like a racer uses, increases safety?
| All times are GMT -8. The time now is 07:18 PM. |
