wilkrod's Avatar
Turbo Twist Fitment
Hi all,
Anyone have any thoughts on putting Porsche Turbo Twist wheels on a 85.5 NA?
Sizes are 7X17, and 9X17.
Thanks for your input.
Jeff
Old 05-23-2011, 11:40 AM
white944cup's Avatar
Your early car comes with 23.3 mm offset wheels and the Turbo Twists have the late offset....usually around 50 to 55 mm, which means you will need 25mm or 1" spacers to get the right fit in the fender wells. You car will look something like mine....
1988 944 Turbo
Guards Red - Black Leather
Autothority Stage 2 Chip Set
Weltmeister Strut Tower Brace
1984 944 - Sold to rcecale
Old 05-23-2011, 05:27 PM
Misunderstood User
Have 17's on my 83. Aftermarket Turbo Twists from Wheel Enhancement,com
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 05-24-2011, 07:02 AM
The aftermarket ones are about 5-7 lbs heavier than factory ones. However, they do come in 17" sizes with both 23.3 and 47mm offsets to fit early or late cars.
Old 05-24-2011, 01:24 PM
Misunderstood User
Danny is correct. It is very hard to find 17 inch wheels with the early offset. I am not using spacers.
Jim
1983 944n/a
Old 05-24-2011, 01:52 PM
hello guys need some help
does anyone know where i can find some extended wheel studs for my 86 porsche 944 na?
Old 05-24-2011, 03:19 PM
Looks like Sway-a-way has them.
Cheap way is to get the factory 21mm spacers that came on the rear of '82-85 944NA. Then install longer studs. On the front, you'll need to grind a 30-degree bevel just beyond the centering lip to clear the bearing-cone.
Old 05-24-2011, 05:51 PM
any links on how to remove factory studs and putting on the extended ones
Old 05-29-2011, 07:18 AM
flash968's Avatar
heavy wheels
i hate that the left and right sides of the car look different because the wheels are all the same (one side coming and one side going)
Old 05-29-2011, 08:11 AM
