-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   what octain do you use (http://forums.pelicanparts.com/showthread.php?t=611152)
alan6272 05-29-2011 08:29 AM
Was wondering what oct. you use I read the 944 takes min.91 I use the cheap stuff and it works just fine for me.
jcommin 05-29-2011 09:08 AM
I live in Chicago. Gas isn't cheap here.
mikepellegrini 05-29-2011 09:31 AM
I use regular (87 octane) for my NA and premium (92 octane) for my 951.
I always buy "good" gas (e.g., Union 76, Shell, Texaco), as opposed to el cheapo stuff - like Arco, for instance, or off brands. There's a reason it's so cheap, after all.
ronster 05-29-2011 09:52 AM
My '99 Boxster calls for 92 but we only get 91 in CA. After a visit to The Racing Group a few months ago the Porsche trained engineers there convinced me I could use 89 with no problem. Tried it saw no difference in mileage and performance and have used 89 since. I also only use Chevron and Shell gas.
VirginiaF1 05-29-2011 10:01 AM
Shell 93 at $4/ gal. As of last fueling...
egil 05-29-2011 10:39 AM
98 octane (RON) at a price equivalent to US$10 per US gallon
Guest765 05-29-2011 10:50 AM
i sure hope you're running the boost to justify that.
egil 05-29-2011 11:00 AM
Octane in Europe is displayed as the RON number only, whereas the US uses the average of the RON and MON numbers. So 98 RON is comparable to 93 octane in the US.
Gas prices on the two sides of the pond are not particularly comparable, though :)
flash968 05-29-2011 11:02 AM
it's all about the compression ratio, the ignition controls and the load
i have only ever run the best fuel possible in anything out of which i wanted performance - engine output specifications are rated at the upper range of the octane required - anything less than the upper range specified causes the ignition control systems to retard timing and cost me power - if it says, for example in the case of the 968, 90 minimum to 93, then at even 91 i am losing 4.8hp (the rule of thumb is 1 point in octane represents 1% of power available) - you may not feel it, as it is only a few horsepower, but i feel that anything less than what i can have is cheating me out of some fun
further, even on the denali, which can easily run on 87, if i plan to tow, given that i have reprogrammed it for 89, i bump up the octane to 89 to keep the knock sensors from engaging, which not only makes for more power, but also runs cooler and gets better fuel economy (about 1mpg on that car) - 91 seems to make no difference on that one, and might actually run hotter
Guest765 05-29-2011 11:06 AM
makes sense.
gmorken 05-29-2011 12:13 PM
Have never used anything other than 93 octane and its running 24mpg in the city. Sunoco offers 100 octane at their regular gas stations around the drag race track at Gainesville, FL... it would be fun to give that a try but not at $9.25/gal. :eek:
alan6272 05-29-2011 12:35 PM
I know gas prices are out of this world in most places, here in NC it is now at $3.59 for 87 oct. 2 weeks ago it was $3.98 go figure.
J1NX3D 05-29-2011 01:57 PM
I use 98 ron also. 98 has become more common in NZ over the last 5 yrs. I use 95 in a pinch though.
Jrboulder 05-29-2011 02:21 PM
We have 85 octane here in Colorado. I use 87 in the winter and 85 in the summer. Today the density altitude is 7600. I see no problem using 85 octane.
Jackson
Aufgeladen944 05-29-2011 05:59 PM
I use 93 in the 951.
nynor 05-29-2011 06:42 PM
91
ERAU944 05-29-2011 08:23 PM
the 951S gets 93
the 944 gets 87
as mentioned, octane ratings are anti-knock indexes, not ratings for the performance of fuel.
the higher compression the engine, the higher octane you will need to prevent detonation.
while turbocharged engines typically have lower compressions, the much higher manifold pressures means that the combustion chambers in turn see much higher pressures, and therefore higher octane fuels are required.
to get the best performance, always use the LOWEST octane that you can WITHOUT any kind of detonation/pinging.
on my old miata, that was mid-grade (89) even though the book called for 87. i blame combustion deposits.
James Chimney 05-29-2011 09:59 PM
If I use Shell the 87 I get a little "run on" when I shut the car off and it is hard to start the next time, 89 works better and 93 I see no difference, 89 for me all the time
J1NX3D 05-29-2011 10:08 PM
i should have added, all the 944 n/a's i've seen, sold new in NZ, all have a sticker on the instrument cluster saying 'use 98 octane only'
CatsEyes 05-30-2011 04:00 AM
Same in Australia. Except my sticker's inside the fuel cap.
Aside from the different ratings described above, I believe the US-destination models were re-tuned for lower-octane US fuel.
944s down here will be Euro-spec.
ERAU944 05-30-2011 07:18 AM
you're right, though it was hardware as well as the tuning. the ROW cars had higher compression (different pistons) than the US cars until 1988. that is why higher octane is required.
RedBaron 05-30-2011 07:34 AM
My S2 gets 91 because it states so in the gas door flap. I always either use Shell or Sunoco. The only thing I don't like about the gasoline I buy is that it contains 10% ethanol (one of the many downside of living in CT.)
HondaDustR 05-30-2011 07:36 AM
I use Shell Vpower 93 almost exclusively. I used to use it just for the extra cleaning powers advertised for Vpower, but now running the 944MAX chip requires at least 91. 93 averages around $4.30 around here.
But just fyi, the 8v NA cars do not have knock sensors, and will not lose power on low grade gas and typically don't have any problems, but you can cause damage if they do knock. The 16V motors as well as the turbos have two knock sensors and will retard ignition timing, reducing power. Most cars made in the last 10-15 years work that way, which allows lower grade fuel at the cost of performance and mileage.
I hate how the US couldn't get the high compression pistons the rest of the world gets. The car would be noticably quicker, as 9.5:1 is pretty relaxed in my book. Stupid EPA! :p
J1NX3D 05-30-2011 11:15 AM
Originally Posted by ERAU944 (Post 6051556)
the ROW cars had higher compression than the US cars until 1988.
when it dropped! :(
ERAU944 05-30-2011 01:38 PM
it dropped ROW? to my knowledge, the US spec was raised to meet what ROW was already getting. did the ROW specs change during the production run?
in the US, the 944 power was progressively uprated. there were cam changes in '85.5, the compression increased in 1988, and the displacement increased in 1989 (transition to 944S2 year).
J1NX3D 05-30-2011 01:51 PM
no, in 1988 the individual market engines were gone. for the 'world' engine the compression dropped from what the ROW engine had but was more than what the US engine had. It wasn't a significant decrease for ROW cars, it was just a decrease. Hp dropped from 163 hp for the 1982 - 1987 cars to 160 hp with the 'world' engine. just bragging rights really.
all markets got the base model '89 increase to 2.7 afaik.
VINMAN 05-30-2011 07:51 PM
87
v2rocket_aka944 06-01-2011 05:02 PM
87 is what it wants...thats what it gets
