James Chimney
Bigger Brakes?
I have an 85.5 944 na and just added 16" phones with 1 1/4" spacers up front will turbo/968 or Brembo brakes fit? if so what will I need or do they just bolt right up?
Thanks |
That Guy
You need '86 951 spindles, hubs and rotors for the front. Rear calipers are direct fit, just need some 1/2" washers (the factory used spacers that are basically the same dimensions) to mount the rear calipers. The bias valve is a good idea also.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Toofah King Bad
Keeping in mind, of course, that the factory brakes are excellent, and can pop your spleen with a set of good pads.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
James Chimney
Whats a "bias Valve"?
Toofah King Bad
It's the thing that opens up in your brain when you notice a black guy following you down a dark street.
Oh, wait, Let me google that for you
That Guy
The valve controls how much hydraulic pressures goes to the rear brakes. If your car has ABS it goes inline between the ABS pump and the lines that lead back to the rear brakes. If no ABS, it connects at the left front fitting on the master cylinder, inline between the master and the brake lines. Without it you will have too much rear brake bias which is especially dangerous when braking into a turn.
Garage Helper
Sometimes without the bias valve and turbo brakes if you have an emergency stop and hit the brakes rather hard you will sometimes wind up facing the other direction. Or in other words the car will love to get real loose in the back.
Plus when you add the turbo brake set-up the struts will need to fit the turbo spindles.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
"Dude! You kicked my car.
There's always this option too: Porsche 944 Big Brake Upgrade Kit That way you don't have to change out you spindles or struts or all that other stuff and if you ever wanted to you could go back to 15" wheels.
James Chimney
ASE Master
1989 944S2 (sold after 11 great years) 1980 911SC Weissach (bucket list car) 1975 914 1.8 (future restoration) 1993 968 Coupe 6 speed (new acquisition) |
