Okay, I'm trying to remove my crankshaft pulley...but I ran into a problem. The Hanes' manual says there are four bolts holding the crank pulley, they also have it pictured. I'm not seeing/feeling these four bolts. Am I missing something? My car is an '87 951.
Also...how do I go about using my flywheel lock?
-Kierf. |
I was going to try this job too - but on the NA, not the 951. Let me know what you find out. I'm eager to learn anything you might not find obvious. I find NOTHING obvious!
Jake 1983 Euro 944 (Mine) 2000 BMW 323i (Hers) 1997 Sentra (unclaimed!) |
Your not seeing things. There is one 24mm main that needs to come of first. It requires in upwards of 300ft/lbs to break so be ready with a cheater bar! If you don't already have one get a flywheel lock, or equiveline to lock the pulley in place.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I have a 5' cheater bar and the flywheel lock. I'm not quite sure what I do with the lock.
-Kierf. |
Take the starter off,install the lock so the engine won't turn over,take the 24 mm bolt loose,(I used a torque wrench and a piece of pipe) then slide a pry bar behind the pulley and pry GENTLY that is plastic behind there. When reinstalling (my 83 n/a) book says to torque to 155 ft pounds. torque maybe different for your 951,so make sure you check it out. Good luck
Texas hosts the 928 Owner’s Club OCIC in 2009 www.928ocicdfw09.com 1980 928 5 speed and a few mods.......... ![]() 928 OC member PCA member |
