AFM test results?
with the arm 1/2 way it's only reading 1 volt, with arm 3/4 it's reading 1.3volt, and from 3/4 throttle to WOT it jumps to 7.5 volt. Bad AFM??
dolor et pavor Copyright Last edited by Arizona_928; 06-27-2011 at 01:25 AM.. |
Porsche 944S Club Sport
Hey Brother;
With the door Closed (idle, no vacuum leaks) the reading should be ~0.352-0.46 at idle. at 1/4 1.11-1.125 volts at 1/2 2.16-2.281 at 3/4 3.23 - 3.377 full ~ 4.37-4.52, volts It should never go past 4.6 volts ever...even at full throttle This is what i have measured... ..The voltage sweep should be linear....no jumping in voltage. and good DMM is really need, verify its 0.00 volt calibration.... Hope this post was helpful later.
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
