Effective Hood Insulation Glue Residue Remover?
I'm having a heck of a time removing the old hood insulation glue residue - having tried a product called "OOPS" along with a plastic scraper...which seems to just move stuff around but does not remove it.
At any rate...could anyone recommend a truly effective glue-residue remover? Thanks!
Old 06-30-2011, 06:35 AM
3M adhesive remover is a good product but I find it very volatile (evaporates real quick). Last year I removed a lot of cosmoline (very sticky stuff) and diesel fuel worked the best. It was great. Im not sure it will work for the insulation glue...but it is cheap and readily available...worth a try.
Old 06-30-2011, 06:41 AM
gasoline is a pretty good solvent....
Old 06-30-2011, 09:39 AM
Toofah King Bad
Rasta Monsta's Avatar
+1 on the 3M
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-30-2011, 09:42 AM
