Arizona_928's Avatar
AFM test results?
with the arm 1/2 way it's only reading 1 volt, with arm 3/4 it's reading 1.3volt, and from 3/4 throttle to WOT it jumps to 7.5 volt. Bad AFM??
dolor et pavor
Copyright
Old 06-27-2011, 01:23 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Porsche Crest No Doubt Bad AFM
Hey Brother;
With the door Closed (idle, no vacuum leaks) the reading should be ~0.352-0.46 at idle.
at 1/4 1.11-1.125 volts
at 1/2 2.16-2.281
at 3/4 3.23 - 3.377
full ~ 4.37-4.52, volts It should never go past 4.6 volts ever...even at full throttle
This is what i have measured.....
The voltage sweep should be linear....no jumping in voltage.
and good DMM is really need, verify its 0.00 volt calibration....
Hope this post was helpful
later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 06-30-2011, 12:03 PM
