944 S2 Normal Running Temperature
Just curious, normal for temp indicator to be between 8 & 9 o'clock position? Should it even move from 8:00?
Also, what's your 20W-50 Dino oil brand recomendation?
Old 08-17-2011, 03:20 AM
Proprietoristicly Refined
John_AZ's Avatar
jep32,
I just looked at your car and it is nice! 46K!
per Clarks
Sensors and Gauges - Information, Troubleshooting, and Testing
Oil? I use Castrol GTX 20-50
This is a highly "hotly" debated topic.
Bored? Review pages 1-82
http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html
If you got service records with the car, that would be a good choice.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-17-2011, 05:53 AM
Thank you!
Old 08-17-2011, 08:15 AM
Should I be concerned it does get to 9:00 occasionally? Straight regular antifreeze, or is there some coolant unique to Porsche?
Old 08-17-2011, 08:22 AM
Toofah King Bad
Rasta Monsta's Avatar
I would suggest a phosphate-free coolant, such as Zerex G5.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-17-2011, 08:28 AM
John_AZ's Avatar
No, probably normal temp at times.
On my '88 when I drive up north it will climb to half or a little more. Once I reach the plateau at Sunset Point, it will drop to less than half and below.
You might just get some Simple Green and spray it diluted on the front of the compressor and if possible the front of the radiator. Then take a hose and flush from the fan/engine side to the front bumper. This will clean the fins and not shove the fly wings deeper into the condensor and radiator.
All antifreeze us usually phosphate free. Change it every 2 or 3 years--mileage not considered. Water Wetter can drop your temps--maybe 5 degrees. Won't hurt.
What you have to watch for ---when it happens, and it usually will, is a brown oil film in the reservoir called "milkshake". The oil cooler seals are bad and have to be changed. Just watch oil and coolant levels regularly and you should be OK.
GL
John
Old 08-17-2011, 08:34 AM
ernie9944's Avatar
93-968 same 3.0 L as yours after a hard run idling at 1,100 RMP at this point the fans are one & temp will go down to the quarter mark in approx a minutes or so, it's normal that your temp goes up to 3/4 mark depending on driving condition.Oil is Dino Castol GTX 20W50 same as John.Hope this thread doesn't turn into another oil war.BTW it is recommended to let your car idle a couple of minutes at 12/11 RPM after a hard run before shutting it off,I always thougth that this only apply to a turbo car. But I don't argue with my owner manual.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 08-17-2011, 08:41 AM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Woo-Hoo!!! A new oil thread!!
j/k
Valvoline VR1 conventional 20w-50 for its high zinc and very high flashpoint for dino formula...
Though just a 2.5L 8v with a 10-year genuine Porsche radiator, my hot temp is 9oclock till the fans kick in... then down to 7:45... all this in 100F stop and go.
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 08-17-2011, 09:37 AM
My S2 would usually stay around the second white mark but sometimes it would reach the third mark for just a little while. Most of my driving was between 90-100 F ambient temp with the AC on. Never once has it been over the third mark during my ownership.
Jackson
Old 08-17-2011, 11:59 AM
Thanks all!
Old 08-17-2011, 12:27 PM
ernie9944's Avatar
Jackson
Mine will never go above the first white mark don't matter how hard you drive it on the hwy,cruising around town will bring up halfway between first & second marks.But if barely moving in traffic or waiting at a ligth then it will slowly move to the 3/4 mark then the fans kicks in.Ambient temp here is between 60-80 F most of the summer.
Old 08-17-2011, 12:50 PM
First white mark as in the bottom mark?
That must bee one cool motor.
Old 08-17-2011, 01:10 PM
ernie9944's Avatar
Yes just a touch over the first white mark.(On the hwy)
Old 08-17-2011, 04:08 PM
Sounds like my car is quite normal. Temps in northeast have been quite hot this summer 90-100. The temp "creeps" towards the mid point in traffic until the fans kick in...otherwise locked in on 1st bar while moving. Sounds normal based on your feedback, Thanks all
Old 08-17-2011, 04:14 PM
ernie9944's Avatar
BTW when I bougth the car it had 78,651 klms on it & the deal was that all major maintenance will be paid by the PO ,so no expenses was spare it included all belts rollers ect plus a brand new water pump/stat/ thermo switch & a rad flush with new coolant,(hoses were ok) presently it has 82,123 klms on it, if you add it up it's only 3,472 klms. So lol it better run cool
Old 08-17-2011, 04:38 PM
I have 47 k now, all major maintenance less water pump done at 44 k, hence the concern. I've heard when the h2o pump goes though, it's sudden?
Old 08-17-2011, 04:47 PM
Checked coolant cold, and it's just above the min mark. Will I need to bleed the sys after topping off to max line with prestone 50/50?
I can't find the bleeder bolt...anyone have a pic of where it is?
Old 08-17-2011, 07:59 PM
VirginiaF1's Avatar
Hmmm...
I know the factory spec is to change TB no later than every 45k and WP every other TB change.. ie: 90k
I found in my service records the orig factory WP lasted 122k... until year 2000.
The second lasted 103k... until 2010 when it was still pumping.
I purchased it 4 months ago.
Has Zerex G-05 Phosphate Free
Item #28 ?? 931 106 156 00
Screw plug on:
Porsche 944 Cylinder Head Parts
Old 08-17-2011, 08:41 PM
ernie9944's Avatar
No you don't need to bleed if topping off with a small amount of coolant,be carefull not to over fill,I keep mine just a little over the minimum mark when coolant is cold(as seen in the first pic.___the bleeder plug on an S2 is kind off in an awkard position instead of being upright it located side way coming off the water cooling socket(as seen in the second pic upper rad hose with two clamps)
Old 08-18-2011, 04:01 AM
Awesome....I really appreciate all the feedback!
Old 08-18-2011, 04:50 AM
