first child 84 944
84 944 oneowner's Avatar
200 rpm signal, CCA Battery
I have been reading about some of the people having low volt from battey. So i am thinking that your battery spec for cold cranking amps should be somewhat high in order for dme to fire a signal when 200 rpm range hits. So is this correct? just thinking out loud here. Thanks
Old 09-30-2011, 07:14 AM
Banned
Cold crank amps on the proper sized battery should never be an issue if your battery and charging system are good
Old 09-30-2011, 07:39 AM
