Mixing Tolerance Groups
Hey all,
I'm rebuilding my turbo engine. It's a tolerance group 1 set of pistons/block. The block is pretty scored. My question, is it a bad idea to go with, say a group 2 block? Obviously a group 0 will not work woth the larger pistons. I thought I'd heard you can increase block tolerance vs pistons.
1975 911S - Twin-plugged 3.5L
www.rasantproducts.com
Old 03-02-2012, 05:10 PM
Toofah King Bad
Rasta Monsta's Avatar
Piston coatings can make up for clearance lost to honing. I recommend a machinist with experience with nikasil/alusil bores.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-02-2012, 10:03 PM
