darnellsgarage
Fix batwing?
Have a 2 inch crack in batwing? Any successfully fixed one?
don
Old 11-22-2011, 02:54 AM
All Spooled Up
Time to get creative, it sounds like!
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 11-22-2011, 07:05 AM
Fill and sand like body work. There are some two part liquid polyeurathane products, like is used for filling the transmission mounts.
Mine is cracked in half. I am going to seal the crack with RTV then sandwich it with thin aluminum plates riveted in place.
Old 11-22-2011, 09:48 AM
Capt Squid's Avatar
I fixed the one on my old turbo with a piece of aluminum and pop rivets. If I remember correctly, I could not find an adhesive that would make a good bond to the plastic. Either way you need a piece of aluminum or plastic as a doubler over the crack.
Jim Richmond
944 Spec race car, SoCal NASA & POC
01 Boxster S
Old 11-22-2011, 08:58 PM
All Spooled Up
That's about what I was figuring you'd need to do. Don't expect to find an adhesive that will stick to that black poly.
Old 11-23-2011, 02:32 AM
If you rough the surface up it may be possible to get a better bond. Do you think the long strand fiberglass bondo would work?
Old 11-23-2011, 05:00 AM
951 Scott's Avatar
I had a little more than a 2 inch crack....here is what I did until I can get a new one or possibly fix using . Really simple....drill and Zipties.
Scott
1986 - 951 Stock with 56K miles as of 03.21.2011
2009 - MB C300 Sport AMG - DD
WWW.SaturdayMorningCars.Com - Founder
Old 11-23-2011, 05:40 AM
darnellsgarage
Interesting solutions. Thanks.
don
Old 11-23-2011, 08:19 PM
