What are these parts?
Doing a head gasket on my 84 944. Got the rebuilt head back on (thanks, Bennington Motorsports).
Now I'm ready to put the intake and cam tower back on and button this thing back up, but not until I get a couple of parts that are broken/need replacing.
What are these two things? The first looks to be a plug of some sort with a couple of thin tubes that used to stick out of it but that are now broken. The second is a connector that hooks to the bottom of the intake manifold; I had to saw it off to pull the manifold out of the way. Probably a better way to have done it but here we are.
Thanks for any tips. Part numbers, if you have them handy, would be great. And if you have any tips on how to remove/replace the second, that would really help. Thank you.
Plug thing
Sawn off bit (this is the whole unit that I'm holding together for the pic)
Old 11-25-2011, 08:15 PM
1984 porsche 944 na
ballysdad's Avatar
1st pic looks like a thermo valve
Part Number Description Price Add to Cart
058-131-851-A-M36
Thermo-vacuum valve [More Info]
2nd would be the j boot under the manifold no easy way to reconnect.
http://www.944online.com/cgi-bin/ASI_Store.cgi?Product+skukey_1128446166
1984 Red NA/Sold
1984 Gray NA/Sold
1986 Red NA
1986 Gray NA
Old 11-25-2011, 08:24 PM
Looks like I'm headed for the junk yard.
Old 11-25-2011, 09:48 PM
Custom User Title
mikepellegrini's Avatar
Ha! That looks just like the one on my 83 NA - which I broke when I was installing a heater valve. It's a Temperature control valve for the vapor recovery system (opens the vapor recovery system at a certain temp). And they are expensive as sin.
Fortunately, mine seems to run just fine without it - I just plugged the hoses.
Which admittedly is kinda a half-assed way to deal with it - and might very well impact your smog inspection - but works.
The other looks like a venturi - which are a PITA - they seem to leak. I wasn't aware NA's had venturis, if that's what it is. Where is it and where do the hoses go?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 11-25-2011, 10:11 PM
porschetub's Avatar
Mike;
So you just plugged yours,mine is open, it needs to be plugged right as it can open sometimes?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 11-26-2011, 11:38 AM
Custom User Title
According to Clark's GSM, the valve opens at 58C to start the vapor recovery system ("G" on the diagram). Fuel and Vacuum Line Diagram (1985.5 and Newer N/A 944s) I assume early 944's are similar.
That diagram calls the venturi-like thing an "ejection pump." Item "D."
If you bypassed the valve and ran the vapor recovery system continuously, that probably wouldn't hurt anything. Maybe it would impact starting? I dunno.
Mine I just blocked off the lines so I wouldn't have a vacuum leak - which is also seems to work okay, but may affect emissions.
16 Ford Expedition
Old 11-26-2011, 01:21 PM
