2.7 and 2.5 injector flow rates
Had a a browse around and read thru my cheap reading specs that the flow rate for the 2.7 is less than that of the 2.5 injector,sounds backwards to me.
Can anyone confirm?,I'am asking because I 'am running a 2.5 fuel rail and injectors on my 2.7 because I had a leak @ my 2.7 rail. Could I be running lean?new plugs look ok,thanks |
how does it run?
Idle is a little unsettled but otherwise ok,is the latter fuel rail a better design?,if not I may just go back the the 2.7 injectors in the early rail.
| All times are GMT -8. The time now is 03:06 AM. |
