HKZ Bob's Avatar
My friends 924 no start need help
Hi 924 forum,
I need to help my friends 924 to go back o the road.
After a few month parking in the garage the car was starting with no issue.
It ran for 5 minutes and now it won´t start anymore?
What EMS system Bosch used in the 924 natural asporated.
K-jetronik or L Jetronic or KE Jetronic.
Where should I start to look for.
BR
Bob
Old 11-28-2011, 10:34 PM
if is a 2,0L rest of the world is a K-jetronic
if is a 2,0L USA probably a KE-jetronic(lambda control)
if is a 2,5L(924s) is a L-jetronic
Say every time the year,vin number or engine number so is easy to get information.
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 11-28-2011, 10:59 PM
HKZ Bob's Avatar
Thank you
it is a euro version
MY 1984 2.0 L 125 PS
So it should be K-Jetronic?
BR
bob
Old 11-29-2011, 05:18 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Check the fuel pump relay carefully..If that has failed car won't start.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 11-29-2011, 07:33 AM
no start,2 posibility:
-without fuel
-without spark
Without spark:try to cranck and see if the spark exist,if exist then go to fuel problems
if the spark don't exist problem with coil,ignition modul,sometimes key ignition switch....
fuel trouble(for 924).
-big vacuum leak or blocked fuel distributer plate.Put out one of the injector,bridge the fuel pump relay and with a finger try to move the distributor plate from air cleaner hole and see if fuel goes too injectors
-maybe the fuel filters after years was glocked?
-the cold-start valve maybe doesn't have power or is broken?
-the warm up regulator is glocked and the engine run very lean(the IN fuel line/biger bolt) have a filter behind the bolt and if is opstrubted then the car goes lean and esitate to start).
I wil try to bridge fuel pump and look carefoul what hapened
chrysler 300M
Old 11-29-2011, 12:19 PM
