-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   High beam works......low beam does not. (http://forums.pelicanparts.com/showthread.php?t=64770)
Panzer909 04-04-2002 10:12 AM
I noticed that my right headlight was out yeasterday. Thinking that the bulb was done, I was just going to get another one, but noticed that the hight beam works fine, as does the "flash" beam.
Just the standard low beam is out altogether. Anyone had this happen to them? What da???
ehpower 04-04-2002 10:25 AM
The High beam and Low beam use different filaments. In your case the low beam filament has burned out. All you need to do is replace your headlight. I would recommend replacing both the right and left side together. This also might be a good time to upgrade your headlight to H4 lighting. Hope this helps.
Panzer909 04-04-2002 02:17 PM
Helps a lot thanks.
Yeah, I was considering the H-4 route anyways as the stock lighting rivals most hand-held flash lights. Off to the parts store I go. SmileWavy
