944 rear rotor dimensions
Hello,
I need some measurements from 944 rear rotors, 86 and older, preferrably from turbo rotor. In my pic needed dimensions are: 66, 71 and 180mm. What these are in reality?
I plan to make aluminum hubs for wilwood rotors to use them at rear, i have narrow aluminum arms at the back on my beetle.
Old 01-11-2012, 04:47 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Dimensions change between '86 NA and '86 Turbo rotors at outer diameter.
'86 NA = 289mm
'86 Turbo = 299mm
Dimensions change between '86 NA and '86 Turbo at outer disk thickness.
'86 NA = 20mm
'86 Turbo = 24mm
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 01-11-2012, 07:48 AM
Yes i know that But i am after these dimensions at my pic: 66, 71 and 180mm.
I need to correct the design on my rear hubs for 12.19x0.81 wilwood rotors
Old 01-11-2012, 11:07 AM
Garage Helper
Well sorry about that - The only other dimension I can verify is the inner diameter of the rear parking brake drum at 180mm, and it is the same dimension on both the Turbo and NA.
Old 01-11-2012, 12:01 PM
Ok,
Now i have rear arm dimensions, so parking brake drum dimensions is good for me now, thanks
Old 01-11-2012, 01:01 PM
