HELP...Clutch job and Timing belt
Hi there,
I am starting to replace my clutch wondering how tough of job is it? Do i have to remove the transmission.? Any other advise you might have doing this job? Next the timing belt. Is it hard to replaced the timing belt? Would you install aluminum flywheel and centerforce clutch? Is it worth that much extra money? What would i gain? Thank you, Randy |
Here is my procedure I penned when I did my turbo clutch, hope it helps.
http://www.user.dccnet.com/lmason/951%20Clutch.htm Timing belt I would leave to a shop as it needs to be tensioned correctly. |
Thank you for the great info. That will help alot. Thank you again.
What do you think of the upgrade for the clutch and flywheel? Is it worth the extra money? |
No probelm, glad to help.
No experience with the flywheel or the centerforce, but I would imagine you would only realise the benefits if you were making big HP, thats my opinion. I think the HD cup clutch from saches works well enough . |
IMason, thanks for writing that how-to. I used it a few years ago when I did mine, and it was a hell of a lot closer than the Haynes manual. The haynes manual basicly says: Step 1, remove clutch. Installation is the reverse of removal. Not much help in my book, but yours was right on!
Brent Early85 944 LM6Y Paint Code |
Thanks very much. glad it helped out.
About 60,000 or 70,000 miles ago put a Centerfoprce disk in 924t. Got it on a clearence for around $100. Its been running fine with the Sachs pressure plate that was on car already.
drew1 |
