-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   testing an ignition coil? (http://forums.pelicanparts.com/showthread.php?t=652788)
marbleusmike 01-21-2012 05:09 PM
Testing an ignition coil?
marbleusmike 01-21-2012 05:14 PM
does anybody out there know if I have to disconnect the positive and negative wires running to the coil before testing for resistance... I tested it with wires still attached and got a .9 reading instead of a .4 to .6 reading...
thanks... its snowy and cold out there and it's a little tough to get at those nuts right now.
GreenWater 01-21-2012 07:17 PM
Electrical is my worst subject, but I don't think you have to disconnect the wires to check for resistance. The meter is checking the resistance between the two lead wires that you are touching to the coil, so anything connected going the other way shouldn't change anything.
That is wrong with the car that you are checking the coil. No spark I am guessing. What happened? What car do you have?
Dang, I think I have another coil, but I don't know where it's at, probably my parents garage, 80 miles away, sorry.
John_AZ 01-22-2012 05:45 AM
Coil Test
Here is one explanation:
Porsche Repair: porsche 944 turbo 86', primary resistance, porsche 944
GL
John
