Collapsable Spare - I'm Stumped!
I have owned 944's since 1986 and currently have 10 of them. I recently got one that had the spare inflated. Is there a way to recollapse the spare tire? I have tried a couple of thing but have not had any success.
Old 02-09-2012, 03:19 PM
vacuum.
Old 02-09-2012, 04:10 PM
one of those hand pump/brake bleeders rigged up to schrader or more low tech, use a tie down strap around the OD of the tire, keep sinching it down with the valve open.
"porsche it's an institution"
Old 02-09-2012, 04:42 PM
In the Fires of Hell.....
kdjones2000's Avatar
All I had to do was to let the air out of it, it collapsed back to original form without any issues. Maybe yours has the rubber that is more brittle.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 02-09-2012, 05:16 PM
Thanks, I tried the strap around the tire without success...I'll try the vacuum pump.
Old 02-09-2012, 07:00 PM
ernie9944's Avatar
Why trust a 26 years old spare tire,all you need is this.Will save weigth plus you can stuff all kind of goodies in the spare cubby hole
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 02-09-2012, 07:22 PM
It is an aluminum spare in an '88 Turbo S. I carry fix a flat in case I get a flat...the spare is just for show.
Old 02-09-2012, 07:29 PM
ernie9944's Avatar
Ah! ok ,you should edit your Avatar & your Signature.This will help peoples know what your driving.To do so use (User CP) on top of the page here.
Old 02-09-2012, 07:57 PM
Toofah King Bad
Rasta Monsta's Avatar
Originally Posted by kdjones2000 View Post
all i had to do was to let the air out of it, it collapsed back to original form without any issues.
+1
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 02-09-2012, 10:24 PM
Eric 951's Avatar
The PO may have inflated the spare with fix-a-flat or something similar(since the original compressors are almost always gone). If that is the case, all the goop inside may prevent the tire from collapsing.
Eric
83 911SC/83 944
bunch of Honda 750s
Old 02-10-2012, 06:36 AM
