Turbo Brake Upgrade
I'm planning on upgrading to some 951 Brakes soon, but I ran across a small problem. I have a 88 N/A and I purchased a set of 86 951 calipers. I've read some conflicting things about whether these calipers will fit on 87- turbo/s2/968 spindles and was hoping to hear from somebody who knows if there are any fit problems with these calipers on late spindles. Thanks.
Old 04-18-2012, 02:20 PM
txhokie4life's Avatar
The rears will fit -- you will need adapter plates, or swap for turbo spindles for the front.
Just did this on a '88 924S
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 04-18-2012, 04:05 PM
That Guy
Techno Duck's Avatar
All of the 951 (not including the Turbo S) calipers are interchangeable.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-18-2012, 05:34 PM
Thanks, that's what I thought but a search on the site brought up alot of conflicting info
Old 04-18-2012, 06:32 PM
9FF 9FF is offline
9FF's Avatar
Calipers the same for the turbo the only difference in the 951 brakes is the 86 rotors are different from the other years. You will need the 951 caliper spacers in the rear, turbo brake hardlines in the rear and turbo flexible lines at the front. Oh and the turbo bias valve on the master cylinder, I think that's everything??
Old 04-18-2012, 07:07 PM
doabarrelroll's Avatar
The spindles for the 86' model are different than the 87-88 non s spindles. The 86' calipers use slightly smaller caliper pistons as well IIRC.
Also, yes, for the rears you will need a spacers, maybe like a 5mm washer.
I believe the brake bias valve is the same between the NA and turbo. The 16v has the different bias valve. It's perfect for my setup because I have the 993TT calipers/rotors up front with 968's in the rear.
944S --> 944 turbo S - 2.5L Dry Sleeves, K26/8 Turbo, LR Height Adjustable Motor Mounts (-1/2 in.), LR 3 Piece Xmember, LR 3 Piece Xover Pipe, LR Oil Pan Baffle Kit, 930 Clutch, Lightened Flywheel, Custom RX-7 Oil Cooler, Apexi EBC, Tial 38mm Wastegate, Full 3" SFR Exhaust, etc...
Old 04-19-2012, 09:12 AM
That Guy
The 8v n/a uses no bias valve. The 944S was the only car that had the single piston calipers that came with a bias valve; the 5/33 valve. The 951/S2/968 all had the 5/18 valve (which gives less rear brake than the 5/33).
The spacer in the rear is basically a 1/2" washer inbetween the caliper and hub mounting point. No need to buy or find the Porsche ones.
Jon
Old 04-19-2012, 09:19 AM
Toofah King Bad
Rasta Monsta's Avatar
I have 86 Turbo brakes on my 931 without bias valve. Brakes seem fairly well balanced to me.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-19-2012, 01:57 PM
