-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Stranded at Tim hortons... (http://forums.pelicanparts.com/showthread.php?t=673351)
JD159 04-22-2012 04:33 PM
Cranks but no start. Procedure for checking fuel pump? Luckily I'm close to home-ish.
Update: After it sat for a bit, it fired up. Turned it off, tried again and it wouldn't start. Waited for a while again, started up and drove it home no problem.
vdoman_pro 04-22-2012 05:43 PM
Funny that you should mention being stranded....the wife and I went for the first coffee run of the season and got stranded at the McDonalds in Gatineau-Hull! Two nice ladies showed up with booster cables and gave me a boost. Problem was with the alternator and it wasn't charging enough apparently, and so as I got back into downtown Ottawa, the car died on me. Fortunately, I had applied for the classic Porsche cars road side assistance available to the first 1500 applicants. They were nice enough to allow a tow to my mechanic which was 38 km away, instead of just to the dealership. Haha am I ever glad that I signed up for that free road side assistance. Needless to say it was an eventful first Porsche run for the season!
Fara 04-22-2012 05:47 PM
That sounds an awful lot like vapour lock on the fuel line.
szyzygy 04-22-2012 05:50 PM
http://cdn.wl.uproxx.com/wp-content/...h_simpsons.png
Joe Namath: Excuse me, son.
Bart: Wow! Joe Namath!
Joe Namath: Thats right. My car broke down in front of your house.
Bart: I cannot believe you are here! Do you think maybe you could give
me some pointers?
Joe Namath: Sure! Theres only one thing you need to know to be a great
quarterback.
Mrs Namath: Joe, hunny, I fixed it! It was just vapor lock!
Joe Namath: OK, look, I've gotta run. Remember what I told you!
JD159 04-22-2012 05:54 PM
You know Simpsons quotes like I know Seinfeld quotes.
Did some homework. Going to look into the DME relay. Thoughts?
looneybin 04-23-2012 08:42 AM
+1 on the DME relay
everyone here will tell you to keep a spare in your glovebox
mhr 04-23-2012 11:50 AM
I signed up for the same thing. How long did it take for them to arrive?
JD159 04-25-2012 08:18 AM
Solved. Replaced DME relay as per forum research. Thanks. Those things seem to be pretty reliable. Considering mine is stamped 05/05/86.
vdoman_pro 04-25-2012 07:34 PM
mhr, it took them about 40 to 45 minutes to show up with the flat bed
