968 and 944 rear hatch compatibility
I have a 92 968 coupe in Houston. My rear hatch is creaking at the top left hinge point. Not the hinge but the glass is starting to separate from the metal frame near the hinge.
Two questions-
Will a 944 rear hatch glass and frame be s suitable replacement for my hatch- of course I will want to change over the 968 wing and side trim pieces instead of the rubber 944 spoiler. The real question is, are the glass, frame, hinges and lockposts all compatible from a late 944 to a 968. I have some indication that they are because I saw that someone replace their 944 hatch with a 968 hatch and seemingly had no problems. If they are compatilble I am sure I stand a much better chance of getting a replacement from a 944 than a 968
Can someone direct me to a Pelican Parts tutorial that outlines the steps to repair or reseal a hatch. Luckily thus far there are no leaks in the hatch.
Old 05-05-2012, 11:28 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
See Clark's Garage Home Page for the rear hatch repair.
Garage shop manual, choose "H", Choose Rear Hatch, and go to BODY-17, Rear Hatch - Squeaking
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-05-2012, 02:18 PM
Thanks,
The Clarks Garage tutorial is helpful.
Does anyone know if the 968 and 944 rear hatches are compatible?
Old 05-05-2012, 05:58 PM
Shifter's Avatar
You can swap the whole units over. You cannot put the 968 trim on a 944 hatch as the glass and the frames are different. Unless you use a 91 S2 hatch....
Old 05-05-2012, 08:57 PM
